Homing Problem For A Axis Only
08 Nov 2017 03:29 #101515 by mdtools999
Homing Problem For A Axis Only was created by mdtools999
I have purchased a 4 axis CNC grinder by the company Kaindl in Germany. It uses a Linux CNC program. My problem is that I am unable to home the machine in all 4 axis, it homes fine in X Y & Z axis but not A axis.
Any suggestions would be appreciated.
Peter
MD Tools
08 Nov 2017 16:24 #101524 by Todd Zuercher
Replied by Todd Zuercher on topic Homing Problem For A Axis Only
Did you try manually homing the A-axis? Often rotary axis don't have home switches, and are homed arbitrarily. This might mean that it does not home with the home all button and may need to be homed by it's self. (Just a guess, I've never played with such a configuration.)
If that is not the case, does the A have a home switch? a limit? are they working correctly? Can you jog the A-axis?
09 Nov 2017 11:35 #101544 by rodw
Replied by rodw on topic Homing Problem For A Axis Only
Here's how I set up a rotary axis on my plasma table. I needed a bit of help to sort it out.
Warning: Spoiler!
12 Nov 2017 10:25 #101676 by andypugh
Replied by andypugh on topic Homing Problem For A Axis Only
Looking at the instruction manual on their web page: kaindl.de/en/fsm.html
They seem to be using a very old version of LinuxCNC and one of the less-developed GUI interfaces.
There might be advantages in updating both. But also risks and difficulties.
Time to create page: 0.330 seconds
