Twin turret lathe configuration
8 years 11 months ago #101597 by smalla
Actually this machine will do the very same movement in a mirrored fashion on the Z W axes. But will use two tools so need to set up two compensation points.
So im thinking on writing a wrapper, which will simply negate the W axis, but it might not be hard to copy the XZ Params and turn them into X->U -- Z->(-W)
8 years 11 months ago #101600 by Todd Zuercher
The tool offset table in Linuxcnc has separate columns for each axis. So if you are always using the same pairs of tools together then you can simply have the Z offset in the Z column and the W offset in the W column. (If tool 3 in the Z is always used with tool 3 in the W.) If the pairs of tools are not always the same then you will need to use a separate tool position for each, one tool with the Z offset in the Z column (and no W) and the other tool with the W (in the W column but no Z), then add the two tool offsets using G43.2. The same for X and U if needed.
8 years 11 months ago #101685 by andypugh
smalla wrote: Actually this machine will do the very same movement in a mirrored fashion on the Z W axes.
Is this a railway wheel lathe as was discussed a while ago?
forum.linuxcnc.org/10-advanced-configura...-parallel-axis#73835
8 years 11 months ago #101761 by smalla
Yes, it is a railway wheel lathe. Just didn't know how it is called, and approached the problem on a more generic way.
Thanks for the link, I will read it out.
Time to create page: 0.230 seconds
