Yaskawa SGDG-04GT torque drives
- bevins
- Thank you received: 338
09 Nov 2017 01:00 - 09 Nov 2017 01:02 #101535
by bevins
Yaskawa SGDG-04GT torque drives was created by bevins
I will use 7i77 kit, but these drives are only torque.
Everything setup the same as velocity control except the tuning?
I heard torque mode is harder to tune. Any advice?
/edit: This is for a 3 axis gantry machine so I will use 2.8JA so they need to be tuned really tight.....
Last edit: 09 Nov 2017 01:02 by bevins.
- Thank you received: 1472
09 Nov 2017 04:55 #101536
Replied by Todd Zuercher on topic Yaskawa SGDG-04GT torque drives
Yes it's pretty much the same but you'll probably want a fast computer that can run a fast Servo thread.
- Thank you received: 4652
09 Nov 2017 13:31 - 09 Nov 2017 13:31 #101554
Replied by andypugh on topic Yaskawa SGDG-04GT torque drives
I am running a couple of machines with torque (actually current) controlled drives with a 1kHz servo thread and software commutation with no problems and perfectly adequate performance.
Last edit: 09 Nov 2017 13:31 by andypugh.
