fanuc red cup motors will run with linuxcnc?
17 Nov 2017 06:49 #101927 by Yannis
Hi again to the forum
i find a GMF ROBOTICS S-420 F Robot in a very good price and i m thinking to buy it and use it for parts in my next
lcnc machine
the info i find in the web was very poor
have anyone try to use servo motor (red cup) witch is ac servos and there drivers with linyx cnc
thanks
17 Nov 2017 07:49 #101932 by Todd Zuercher
Replied by Todd Zuercher on topic fanuc red cup motors will run with linuxcnc?
The answer is a definite maybe, but probably more trouble than they are worth. If they are old enough that the drives have analog inputs you can probably get them to work. If they interfaced with the control via optical cables, then probably not.
The following user(s) said Thank You: Yannis
17 Nov 2017 08:01 #101934 by Yannis
the only info provided by the web page is that the robot build in 1992
is this any help?
17 Nov 2017 08:56 #101937 by Todd Zuercher
Not much. That is old enough to possibly be analog, and not have serial encoders. But I don't know for certain. You really almost have to check part numbers on the drives and encoders.
There are others much more knowledgeable on this subject around here.
20 Nov 2017 11:25 #102074 by andypugh
Replied by andypugh on topic fanuc red cup motors will run with linuxcnc?
The linuxcnc "bldc" module knows how to interpret the red-cap commutation signals, and can convert to conventional hall signals (amongst other things).
I assume that you do not have the original drives?
linuxcnc.org/docs/2.7/html/man/man9/bldc.9.html
