tool changing
- jlroch
19 Nov 2017 19:21 #102032
by jlroch
tool changing was created by jlroch
hi all. new problem (i know, i know, there are no problems, just solutions waiting to be discovered)....
i am using autodesk artcam along with linuxcnc to get my projects done.
my cnc does not have a tool changer. so when the gcode encounters a tool change, it stops dead where it is, asks for the tool to be changed, and displays the "continue" button. so here is the problem:
where it stops is generally too low to change the bit. in order to change the bit, i have to "stop" the program, raise it with "page up", and change the bit. i then re-home all the axis to zero. when i try to continue, it starts from the top of the gcode (which of course is bad because the wrong bit is in the spindle).
i tried highlighting the gcode line after the requested tool change and restarting, but it still goes back to the the first line of code.
so, my questions are:
1) what is the correct procedure to change a bit when requested.
2) how does one (if at all possible) jump to different points in the gcode execution (for instance to re-cut a given vector)
jacques
jacques
- jlroch
22 Nov 2017 15:43 #102190
by jlroch
Replied by jlroch on topic tool changing
anyone??
- Jake
- Thank you received: 10
22 Nov 2017 16:11 - 22 Nov 2017 16:24 #102193
by Jake
Replied by Jake on topic tool changing
You need to change your tool change location
This will be in your .INI file If it is not in your .INI file add it, it will send the quill or head to the max Z position for the tool change.
check out the EMCIO section in the INI configuration
linuxcnc.org/docs/2.6/html/config/ini_co...ml#sub:EMCIO-Section
In AXIS you can right click in the line of Gcode you want to start at and it will say "run from here"
# Tool change with Z axis up
TOOL_CHANGE_QUILL_UP = 1This will be in your .INI file If it is not in your .INI file add it, it will send the quill or head to the max Z position for the tool change.
Last edit: 22 Nov 2017 16:24 by Jake. Reason: deedadee
- jlroch
22 Nov 2017 16:40 - 22 Nov 2017 16:41 #102195
by jlroch
1) any special place in the ini file?
2) what about homing the z after the tool change?
jacques
jacques
Last edit: 22 Nov 2017 16:41 by jlroch.
- Jake
22 Nov 2017 16:49 #102197
by Jake
mine is in my EMCIO section
As for the homing after Z....you wont unhome the machine on a tool change. Do you mean setting tool offset? If you have set tool holders like CAT40, set them before you run the program so the offsets are in the tool table. If you have R8 collets, or a router I am not sure the best way to handle it. Search "touching off after tool change" There are guys with collet system machines that will have to touch off for each change.
# section for main IO controller parameters -----------------------------------
[EMCIO]
# Name of IO controller program, e.g., io
EMCIO = io
# cycle time, in seconds
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = ppmc.tbl
# Tool change with spindle off
TOOL_CHANGE_WITH_SPINDLE_ON = 0
TOOL_CHANGE_QUILL_UP = 1As for the homing after Z....you wont unhome the machine on a tool change. Do you mean setting tool offset? If you have set tool holders like CAT40, set them before you run the program so the offsets are in the tool table. If you have R8 collets, or a router I am not sure the best way to handle it. Search "touching off after tool change" There are guys with collet system machines that will have to touch off for each change.
- jlroch
22 Nov 2017 16:55 #102199
by jlroch
yeah, i have collet, so i guess that i mean "setting tool offset" (i am a newbie-- i have had this machine for just a few months and i am "home schooling" myself. the good news is that i have an extensive computer back ground as well as extensive woodworking knowledge (see: www.atelierdebois.com).
i will try your suggestions and get back to you.
jacques
jacques
- Jake
22 Nov 2017 17:01 #102200
by Jake
forum.linuxcnc.org/10-advanced-configura...h-off?start=80#89934
it appears that the MTC and touchoff is in this thread, glad I dont have to deal with that!
- verticalperformance
- Thank you received: 11
24 Nov 2017 23:49 #102322
by verticalperformance
Replied by verticalperformance on topic tool changing
Simplest thing to do with collet type holders that may get loaded to different heights each time is to break the gcode up into multiple files, one per tool.
Home and touchoff x,y,z for the first program, run it and let it finish. Might be helpfull to have a G0 Z(to suit machine) to move the tool up out of the way.
Load the second tool in the collet, ad the second g-code.
Touch off the z only on a known height (top of part, table, setting block whatever)
Run the second g-code.
Repeat for each tool and associated g-code.
With this method, you don't need to have accurate tool lengths in the tool table.
Not very elegant, but if it is more important to make parts, this will always work
There are more elegant solutions, where you have some sort of switch that you can touch the tool onto at each tool change and set it's length dynamically - search the forum. I now use tool holders that you can preset the length prior to using, so don't have the same issue anymore.
- jlroch
26 Nov 2017 00:48 #102343
by jlroch
yep, i think i will follow your advice. and yep, while not elegant, it's simple and effective.
can you tell me more about the tool holder that you use? is it an automatic tool changer or something else?
jacques
jacques
- BigJohnT
- Thank you received: 994
26 Nov 2017 03:38 #102345
by BigJohnT
Homing establishes the MACHINE XYZ zero position. After homing you "touch off" a tool usually to Z0 of the material top.
gnipsel.com/linuxcnc/g-code/gen05.html
JT
Replied by BigJohnT on topic tool changing
jacques
JT
Time to create page: 0.106 seconds
