HL3000-2022 T - VFD frequency inverter
  • probamo
  • probamo's Avatar Topic Author
  • Premium Member
  • Premium Member
21 Nov 2017 21:49 #102155 by probamo
Hi All,
is there anybody having and experience wiring and setting HL3000 inverter in LinuxCNC.
mymonday
rituo
In particular I am interested in RS485 communication port, adopting standard international MODBUS main circuit control.
Spindle at speed indication not provided, no feedback and tuning more precise spindle speed response of VFD set through Axis/Gmmocapy control panel. PWM from breakout board were wired at the terminals 10V, FV and COM respectively.
Thank you
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
22 Nov 2017 03:27 #102173 by Todd Zuercher
Replied by Todd Zuercher on topic HL3000-2022 T - VFD frequency inverter
Unfortunately no two drive manufacturers implement Modbus exactly the same, and there isn't even any guarantee of compatibility between different models from the same source. You are going to need to track down good documentation from the manufacturer how to configure the RS485 connection. (or find a driver for it that someone that has already done all that set up work for it already.)
Time to create page: 0.131 seconds
