Can't go negative X
- fishtruk
22 Nov 2017 20:55 #102219
by fishtruk
Can't go negative X was created by fishtruk
We aren't the sharpest pencils with any of this, but have an issue.
We have a simple 1 axis procedure which worked before but not now.
I've isolated 1 fact. I can't move to a negative X position. I've expanded all the limits I can find regarding this movement but nothing seems to work.
Just now I made all the movements positive to quick fix but everything I've tried does not work. There's only 1 ini I can find, 5axis.ini but I've expanded all those limits and no fix
Is it possible that some toggle somewhere won't let me go negative X?
Any help is appreciated.
Thanks,
Nelson.
Thanks,
Nelson.
- Thank you received: 1472
22 Nov 2017 21:13 #102222
Replied by Todd Zuercher on topic Can't go negative X
Could you post your ini file for us to look at to see if we can see what is limiting your travel.
- fishtruk
22 Nov 2017 22:30 #102227
by fishtruk
Replied by fishtruk on topic Can't go negative X
Thanks, seems someone may have messed with it.
Time to create page: 0.075 seconds
