Confusing install Linux on new machine
- shedeck
23 Nov 2017 00:45 #102232
by shedeck
Confusing install Linux on new machine was created by shedeck
I have been going through the process of installing linuxcnc.org/linuxcnc-2.7-wheezy.iso on a USB, booting the system and installing it on to a computer. Linux installs fine on the computer but LinuxCNC is nowhere to be found. I was under the assumption that the ISO file I was using installs Linux and linuxCNC. Can't find any files or directories relating to linuxCNC. Was I mistaken in thinking that the ISO file installed Linux and Linuxcnc?
- ozzyrob
- Visitor
23 Nov 2017 01:04 #102234
by ozzyrob
Replied by ozzyrob on topic Confusing install Linux on new machine
There should be a menu item.
What happens if you open a terminal and type: linuxcnc ?
- shedeck
23 Nov 2017 01:19 #102236
by shedeck
Replied by shedeck on topic Confusing install Linux on new machine
Command not found
- ozzyrob
- Visitor
23 Nov 2017 01:37 #102238
by ozzyrob
It should install linuxcnc......why it hasn't ? Good question, have you tried reinstalling (I know probably not a lot of help, more like a Windows tech support suggestion ?
Can you run linuxcnc when booted live ?
- Thank you received: 7471
23 Nov 2017 02:17 #102242
Replied by tommylight on topic Confusing install Linux on new machine
Disconnect the internet before installing wheezy.
On strech you need the internet or it will not install.
- shedeck
23 Nov 2017 02:57 #102244
by shedeck
Thanks, I will try it.
JON
JON
Time to create page: 0.389 seconds
