Angle of motor rotation and CNC unit relationship
8 years 11 months ago - 8 years 11 months ago #102523 by bodhi_94
I'm having a problem of find the angle of motor rotation and CNC unit relationship. I mean for 1 inch = 'theta' degrees of rotation in X axis. I tired to measure it but gave no accurate results. Anyone knows to find it mathematically.?
Thank you.
Last edit: 8 years 11 months ago by bodhi_94.
8 years 11 months ago #102538 by PCW
On a normal linear axis (you mentioned X) and assuming a screw for
translating the motor rotary motion to linear motion, this would depend on
the screw pitch. So for example if you had a 5 TPI ballscrew on X,
directly driven by the motor, you would have one motor rotation for 0.200"
of motion or 1800 degrees (5 turns) per inch
The following user(s) said Thank You: bodhi_94
Time to create page: 0.248 seconds
