Angle deviation
- kronikary
30 Nov 2017 20:22 #102544
by kronikary
Angle deviation was created by kronikary
Hi! I'm new here.
Is there any plugin to linuxcnc that finds the angle deviation? It's exactly shown in the video below (time 1:04):
Eventually can you tell me how to write that plugin?
Greetings
Greetings
- MaHa
- Thank you received: 240
01 Dec 2017 22:35 #102575
by MaHa
Replied by MaHa on topic Angle deviation
Try this, just for angle deviation. Measure 2 points on one side of your workpiece.
Your probe must be positioned at startposition xyz. Feed is fixed 100%, otherwise remove M50P0.
Metric G21. CS 1 (G54) is used by this routine. Use another cs for machining.
Global param #<_ANG> contains measuring result.
use o<check_r_cor> in preamble recommended, to find R rotation left behind in any cs, to avoid bad experience.
1 [Traveldistance (+ -) to measuring point]
2 [Distance (+ -) between measuring points]
3 [Travel axis 1 or 2]
o<adev> call [-6] [-65] [2]
G10 L2 P2 R#<_ANG>
o<check_r_cor> call
G10 L2 P2 R#<_ANG>
o<check_r_cor> call
- Thank you received: 4652
06 Dec 2017 17:15 #102726
Replied by andypugh on topic Angle deviation
This discussion might be interesting:
forum.linuxcnc.org/40-subroutines-and-ng...a-plasma-table#29170
There is also the probe screen, and angular alignment is one of the options there:
forum.linuxcnc.org/49-basic-configuratio...h-probe?limitstart=0
Also note that LinuxCNC can rotate the coordinate system around Z to compensate for out-of-square workpieces:
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g10-l2
The following user(s) said Thank You: BigJohnT
