PID and Homing with index.
  • UAVpilot
  • UAVpilot's Avatar Topic Author
  • New Member
  • New Member
08 Dec 2017 22:36 - 08 Dec 2017 22:37 #102799 by UAVpilot
PID and Homing with index. was created by UAVpilot
Hello,
I have this configuration:
5i25 or 7i92 -> 7i77 -> servo (fast)
At the end of the process homing, the servo drive jerks sharply and sometimes shuts down due to overload. I found out why this happens:
At the signal index-enable (falling to low), the encoder counter pid.x.feedback do reset. However, pid.x.command will only be reset in the next servocycle. As a result, in the current servocycle, pid.x.error becomes
equal pid.x.command and a very large value appears briefly at the output of PID (pid.x.output). A fast servo manages to do it.
The PID component has a pin pid.x.error-previous-target, which is TRUE by default. If change it to FALSE, the result is slightly improved, but the problem does not resolve.
Last edit: 08 Dec 2017 22:37 by UAVpilot.
  • UAVpilot
  • New Member
  • New Member
08 Dec 2017 22:44 #102800 by UAVpilot
Replied by UAVpilot on topic PID and Homing with index.
I made a small patch for pid.c, which seems to completely solve this problem:
--- pid.c.orig	2017-11-25 04:26:15.000000000 +0300
+++ pid.c	2017-12-09 01:36:06.645777032 +0300
@@ -325,6 +325,8 @@
     } else {
         tmp1 = command - feedback;
+    if(pid->prev_ie && !*(pid->index_enable))
+	tmp1 = 0;
     /* store error to error pin */
     *(pid->error) = tmp1;
     /* apply error limits */
Results:
08 Dec 2017 22:50 #102801 by Todd Zuercher
Replied by Todd Zuercher on topic PID and Homing with index.
Do you only have a servo thread?
I have this same problem on a machine that is running a servo thread and a floatingpoint base thread, For me the problem goes away If I run only a single thread. Also if I try to home the machine again after the error, it does not do it because the encoder offset was zeroed with the first failed attempt. (I only get the error after closing and restarting Linuxcnc.)
  • UAVpilot
  • New Member
  • New Member
08 Dec 2017 23:07 - 08 Dec 2017 23:09 #102804 by UAVpilot
Yes, only servo thread.
Stable way to reproduce the problem:
1. Move the axis (mechanically) to a distance of 30mm or more from the home switch.
2. Start LinuxCNC.
3. Start the homing procedure.
Last edit: 08 Dec 2017 23:09 by UAVpilot.
09 Dec 2017 00:36 #102807 by Todd Zuercher
Do you have pid.N.index-enable connected?
09 Dec 2017 01:10 #102808 by PCW
Replied by PCW on topic PID and Homing with index.
If pid.N.index-enable is connected and you still get this issue it may be a thread order problem
Can you post your hal/ini files?
  • UAVpilot
  • New Member
  • New Member
09 Dec 2017 12:36 - 09 Dec 2017 12:46 #102817 by UAVpilot
index-enable connected.
hm2_7i92.0.encoder.00.index-enable <=> pid.x.index-enable <=> axis.0.index-enable
INI & HAL, inessential removed:
Warning: Spoiler!
I tried to change the order of the components in the thread - the result does not change. As expected.
addf pid.x.do-pid-calcs servo-thread
Last edit: 09 Dec 2017 12:46 by UAVpilot.
09 Dec 2017 14:32 #102823 by PCW
Thread order is wrong, it should be:
hardware read
everything else
hardware write
  • UAVpilot
  • New Member
  • New Member
09 Dec 2017 21:59 - 09 Dec 2017 22:02 #102851 by UAVpilot
So?
loadrt hostmot2
loadrt [HOSTMOT2]DRIVER0 board_ip=[HOSTMOT2]BOARD0IP config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
addf hm2_7i92.0.read servo-thread
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt pid names=pid.x,pid.z,pid.s
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
I tried it. As expected, the problem remained.
I noticed that on the given oscillograms I was mistaken in the designation of cycles: The inscription "Cycle N + 1" should be read as "Cycle N + 2". Below is the correct picture. Sorry.
My patch causes the PID to skip the cycle N+1
Last edit: 09 Dec 2017 22:02 by UAVpilot.
09 Dec 2017 22:26 #102852 by PCW
I suspect there's still a hal file issue of some kind as this is not a common problem with home to index
The feedback position should change at the same time as and the commanded position. If not
that still suggests a thread order or HAL connection problem
Can you post your complete hal and ini files?
Time to create page: 1.391 seconds
