Cannot get motors to move
12 Dec 2017 11:03 #102984 by AzzA
Cannot get motors to move was created by AzzA
Hi, I am trying to set up and wire a mill conversion, but I cannot get any motors to move.
I am using Mesa 6i25 and 7i76. I can get a coolant output to work and all X,Y,Z direction signals work.
I will be using servos, but at the moment I am using a stepper to test with.
Step spacing is set to:
STEPLEN = 2500
STEPSPACE = 2500
Voltage across Step- and step+ is -4.75v and when I try to jog an axis it changes to -4.70v. Swapping step- and step+ does not make it work and the direction signals were on the board where I expected them to be so I do not think I am using the wrong pins.
Does anyone have any ideas why this might not be working?
Cheers
Alan
File Name: my_LinuxCN...hine.ini
File Size:4 KB
12 Dec 2017 12:51 #102989 by BigJohnT
Replied by BigJohnT on topic Cannot get motors to move
Is the stepper drive powered up and the stepper motor warm and holding position?
JT
12 Dec 2017 15:48 #103006 by PCW
Replied by PCW on topic Cannot get motors to move
if the voltage across STEP+ and STEP- reverses when you jog it suggests that you have step and direction swapped.
13 Dec 2017 01:30 #103055 by AzzA
Replied by AzzA on topic Cannot get motors to move
The stepper is on and has holding torque. I can also make it step by manually applying 5v.
The voltage across Dir- and Dir+ swaps for all 3 axis when I try to jog in the negative direction.
Cheers
Alan
13 Dec 2017 04:00 #103058 by PCW
Try doubling the step length
13 Dec 2017 04:24 #103060 by AzzA
That did the trick. Thanks PCW.
I did not think to change that as it seemed to be in the higher range of suggested values.
Cheers
Time to create page: 0.171 seconds
