CNC with wincam / winplasma software
- Peskanova
14 Dec 2017 12:51 #103108
by Peskanova
CNC with wincam / winplasma software was created by Peskanova
Hi , first of all thank you for letting me in, im a bet newbie on this subject (tho i have great programming skills) but where i work there is a cnc plasma machine (from early 90's) controlled by an old computer and it seems that has somo integrated hardware to talk with the software (wincam/winplasma) i have tried to clone my computer (because that program only runs on win 98 ) but cant override security so i was thinking if i can make a similar use with that machine with linuxcnc , if someone can give me a clue where to start i have access to all files (cnc is working well but i'm afraid that computer wont last long) , so please if someone can advice me how and where to start i will be so grateful
thanks in advance (sorry for my bad english)
i post some images of the cnc's
- bevins
- Thank you received: 338
14 Dec 2017 13:18 #103109
by bevins
Replied by bevins on topic CNC with wincam / winplasma software
Open that orange box and take some closeup pics of the internals.
Then we can suggest something.
The following user(s) said Thank You: Peskanova
- Peskanova
14 Dec 2017 15:48 #103116
by Peskanova
Replied by Peskanova on topic CNC with wincam / winplasma software
- Thank you received: 4652
17 Dec 2017 02:16 #103178
Replied by andypugh on topic CNC with wincam / winplasma software
Hard to tell what is in the box in detail, but I would suggest that a vacuum cleaner would keep it running a bit longer.
It looks like, probably, two servo drives. Do those have any markings on them?
- FabrizioIT
13 Feb 2018 08:49 #105813
by FabrizioIT
Replied by FabrizioIT on topic CNC with wincam / winplasma software
Hello guys,
the machine in picture use a cnc that is not based on operating system but it use a z80 processor board.
The computer where is installed the program Winplasma/Wincam is based on windows OS and in this case you can
use a linux pc and a virtualized windows to run it. Be aware the software need a security access so you need to verify if this can be updated. I am able to provide upgrades. Contact me for any requests This email address is being protected from spambots. You need JavaScript enabled to view it.
- Mic2022
01 May 2022 06:57 #241772
by Mic2022
Replied by Mic2022 on topic CNC with wincam / winplasma software
Dear Peskanova,
I'm Mic from Germany and hope that you can help me. I bought a similar machine like you. The big problem is that I don't have the winplasma program. And I don't have the required dongle, too. Do you get your machine running?
- Thank you received: 7468
01 May 2022 09:34 #241781
Replied by tommylight on topic CNC with wincam / winplasma software
Hallo Mic,
I would suggest starting a new topic as this one stalled with no solution.
Machine looks nice.
Retrofitting it is doable for sure, it uses 2 servo drives and probably a separate drive for Z if it has THC.
See Andy's reply/request above, do a lot of pictures of everything inside the cabinet, wiring, motors, encoders, tachos, etc. That makes it much easier for us to help.
Machine looks nice.
- Mic2022
02 May 2022 10:15 #241840
by Mic2022
Hallo Tommy,
thanks for your quick answer! This week I will clean up the machine a bit and try to make some signigficant pictures of everything. I will let you hear.
Time to create page: 0.222 seconds
