Here we go...
8 years 10 months ago #103412 by megaplow
Replied by megaplow on topic PM-940-CNC
That's the one!
Attached is an image of the goodies. The image is not my machine, mine has the nMotion controller which is getting swapped out for a 7I76e and LinuxCNC.
8 years 10 months ago #103417 by fc60
Replied by fc60 on topic PM-940-CNC
Greetings,
The wiring looks nice and tidy.
Is the vendor installing the 1716e for you? Or, do you have to install it yourself?
Always nice to have someone supply a working machine.
I was also impressed with the Flame Hardened ways!
Looking forward to your next report.
Any chance you are in the Seattle, WA USA neighborhood?
Cheers,
Dave
8 years 10 months ago - 8 years 10 months ago #103420 by megaplow
Sadly no, the vendor is not installing the 7I76 for me. When the machine arrived, I went about setting up mach3. The motion was off and I couldn't find a machine profile for mach online. The 7I76 kept popping up in my searches and since I was never a mach3 expert, I thought why not give it a go?
Tonight I labeled all the important wires. After that I am going to remove the electronics panel from the back of the mill and put it on the wall. Then I will do the 7I76 install. Till then I will be compiling my rt kernel....
Last edit: 8 years 10 months ago by megaplow.
  • ozzyrob
  • New Member
  • New Member
8 years 10 months ago #103422 by ozzyrob
Replied by ozzyrob on topic PM-940-CNC
Geesh you'd think they'd supply a config for Mach3 and test it before sending the machine out.
Pretty poor form from the supplier.
Anyways Linuxcnc has a bit of learning curve during the initial setup but as you learn more you see how much easier it is than Mach3 to get thing just the way you like.
8 years 10 months ago #103426 by andypugh
Replied by andypugh on topic PM-940-CNC
megaplow wrote: Till then I will be compiling my rt kernel....
No need for that! I know Linux has a reputation but sometimes things are reasonably easy.
Set the controller PC up with this installer image:
www.linuxcnc.org/testing-stretch-rtpreempt/
You will want one of the the amd64.iso files. (Probably the r9, but if that has trouble installing, try the r8)
7 years 8 months ago #127353 by 5axisormore
Replied by 5axisormore on topic PM-940-CNC
Has anyone else done a PM-940-CNC? One of the guys I work with just got one and is looking to go the 7166E route as soon as they are in stock again. It actually is a pretty nice looking mill with a wide dovetails compared to the rest of the mills that size. It came with a 4th axis rotary table, but could be interesting with the Dakota 5 axis table setup that a group of CalPoly students made for HAAS OM mill. digitalcommons.calpoly.edu/mesp/305/ is the download of their paper with the drawings and parts list.
I was hoping to contact Megaplow and see how well his project went.
Fred
Time to create page: 0.342 seconds
