what is HOME in TRAJ mean?
- thang
- Thank you received: 11
22 Dec 2017 21:30 #103470
by thang
what is HOME in TRAJ mean? was created by thang
i read document but i didnt understand how it work, i tried random change it but i didnt see anything change when i run linuxcnc
- Thank you received: 2182
23 Dec 2017 04:55 #103482
Replied by cmorley on topic what is HOME in TRAJ mean?
linuxcnc.org/docs/2.7/html/config/ini-config.html#_traj_section
HOME = 0 0 0 - Coordinates of the homed position of each axis. Again for a fourth axis you will need 0 0 0 0. This value is only used for machines with nontrivial kinematics. On machines with trivial kinematics this value is ignored.
Without more info it's hard to help you.
If your machine is a regular XYZ machine then it does nothing - it's ignored.
Chris M
Chris M
The following user(s) said Thank You: thang
- thang
23 Dec 2017 06:13 #103486
by thang
Replied by thang on topic what is HOME in TRAJ mean?
my machine is an robot arm 6dof like puma560. I have set home's joints are 0 0 0 0 -90 0
23 Dec 2017 19:16 #103511
I'm sorry I don't know much about non trivial kin machines.
Hopefully someone else can answer.
More information about your machine would help.
posting your config files would help.
Chris M
Chris M
Time to create page: 0.075 seconds
