Pull requests from github
- persei8
- Thank you received: 133
04 Jan 2018 00:17 #104001
by persei8
Pull requests from github was created by persei8
I am trying to update gmoccapy from 1.5.8 to the latest version. I could not find any instruction beyond "pull from master" so this is not very helpful. Downloading files from the repository using wget result in useless HTML files. I can download them in raw format but have no idea where to put them. Using git clone results in the following:
git clone github.com/LinuxCNC/linuxcnc/tree/master...mc/usr_intf/gmoccapy src
Cloning into 'src'...
remote: Not Found
fatal: repository 'github.com/LinuxCNC/linuxcnc/tree/master...c/usr_intf/gmoccapy/' not found
I can usually figure stuff out eventually, but this one has me stumped. I'd appreciate any help. Thanks.
remote: Not Found
11 Jan 2018 12:01 #104281
Replied by andypugh on topic Pull requests from github
You can get a set of zip files from the green "clone or download" button.
I think that to be able to do a pull request you would need to clone the entire source tree, rather than just one file, ie:
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
The following user(s) said Thank You: persei8
- persei8
11 Jan 2018 18:30 #104302
by persei8
Replied by persei8 on topic Pull requests from github
When I go to github.com/LinuxCNC/linuxcnc/tree/master...mc/usr_intf/gmoccapy, there is no "clone or download" button. I'm probably at the wrong location. Not to worry though. I managed to build the latest master version although I didn't really want to build the entire kernel and rt patch but it's done now and working well. On to the next problem.
