Running simulations
  • persei8
  • persei8's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Jan 2018 00:08 #104191 by persei8
Running simulations was created by persei8
How would I modify the files for a real machine so that I can simulate them without being hooked up to real hardware? I am trying to get the craftsmancnc UI working but there is no stepconf file for it. I have looked at the sim configs for the standard UIs but cannot determine exactly how they work. Thanks.
11 Jan 2018 01:14 - 11 Jan 2018 01:16 #104267 by Grotius
Replied by Grotius on topic Running simulations
@Persei8,
If you look at this thread, maybe it helps you, good luck !
Read it carefully. if things are not clear after you read the topic's, you can ask again.
Mr. aer73 is also asking for craftman install help.
craftman cnc topic
Last edit: 11 Jan 2018 01:16 by Grotius.
11 Jan 2018 02:08 #104270 by cmorley
Replied by cmorley on topic Running simulations
are you using master? is it a parallel port config if so stepconf can make simulated configs using special components.
if you are not using master then you could modify a sim config.
if you are using a mesa card you are outta luck.
The following user(s) said Thank You: persei8
  • persei8
  • Platinum Member
  • Platinum Member
11 Jan 2018 18:45 #104306 by persei8
Replied by persei8 on topic Running simulations
I've read that thread several times in fact. Hopefully, it will be revived as I like that UI and would like to get it working. Thanks.
