Trying to run first metal part on new mill conversion
- JohnnyCNC
- Thank you received: 115
09 Jan 2018 01:49 #104193
by JohnnyCNC
Trying to run first metal part on new mill conversion was created by JohnnyCNC
Hi All,
I have a Sieg X3 mill with a Mesa 5i25+7i76 running LinuxCNC. I created a part in Fusion 360 and did the cam in there too. I'm not sure where I should be asking this question CNCZone, Fusion360 forum, or here so I'll start here. This is a simple drilling operation. When I run the part, the X & Y look OK but the Z does not go deep enough. It should be a hole through 1/8 inch aluminum but is only goes about have way through. In the Fusion simulation the bit goes well through the part. I tried some commands on the MDI tab and the Z moves 1 inch when commanded to do so. I tried jogging to make sure I wasn't hitting a soft limit. Each time I run the program it get just the slightest chip when the drill touches the bottom of the hole. I just don't know what else to check.
- BigJohnT
- Thank you received: 994
09 Jan 2018 11:49 #104198
by BigJohnT
Replied by BigJohnT on topic Trying to run first metal part on new mill conversion
Did you look at the G code?
JT
JT
- JohnnyCNC
09 Jan 2018 15:59 - 09 Jan 2018 16:40 #104206
by JohnnyCNC
Replied by JohnnyCNC on topic Trying to run first metal part on new mill conversion
Reading G Code is still a lot like reading Spanish for me. I'll go through it today since I am off.
JT, are you on the Spyder Lovers forum? You look familiar.
Here is the code
Could it be this line? N65 G43 Z21.35 H2 How would Fusion know the length of my tool when I don't even know that until I touch it off? I using R8 collets and a drill chuck to drill bits. I'm going to try changing it by 5mm and see what happens.
I'm still trying to understand how to perform manual tool changes with R8 collets. Eventually I going to get tool holders so I can set the tool lengths and put them in the tool table.
(ZSWITCHPLATE)
(T2 D=5. CR=0. TAPER=118DEG - ZMIN=-3.502 - DRILL)
(T3 D=1.6 CR=0. TAPER=118DEG - ZMIN=-2.481 - DRILL)
N10 G90 G94 G17 G91.1
N15 G21
N20 G53 G0 Z0.
(DRILL1)
N25 M9
N30 T2 M6
N35 T3
N40 S2000 M3
N45 G54
N50 M9
N60 G0 X5. Y6.
N65 G43 Z21.35 H2
N75 G0 Z11.35
N80 G98 G81 X5. Y6. Z-3.502 R11.35 F728.
N85 X80.
N90 G80
N95 G0 Z21.35
N105 M5
N110 G53 Z0.
(DRILL2)
N115 M9
N120 M1
N125 T3 M6
N130 T2
N135 S2000 M3
N140 G54
N145 M9
N155 G0 X14.696 Y9.9
N160 G43 Z21.35 H3
N170 G0 Z11.35
N175 G83 X14.696 Y9.9 Z-2.481 R11.35 Q0.4 F400.
N180 X24.196
N185 X37.699
N190 X47.199
N195 X60.473
N200 X69.973
N205 G80
N210 G0 Z21.35
N220 M9
N225 G53 Z0.
N230 M30
Here is the code
(ZSWITCHPLATE)
N15 G21
N20 G53 G0 Z0.
(DRILL1)
N25 M9
N30 T2 M6
N35 T3
N40 S2000 M3
N45 G54
N50 M9
N60 G0 X5. Y6.
N65 G43 Z21.35 H2
N75 G0 Z11.35
N85 X80.
N90 G80
N95 G0 Z21.35
N105 M5
N110 G53 Z0.
(DRILL2)
N115 M9
N120 M1
N125 T3 M6
N130 T2
N135 S2000 M3
N140 G54
N145 M9
N160 G43 Z21.35 H3
N170 G0 Z11.35
N180 X24.196
N185 X37.699
N190 X47.199
N195 X60.473
N200 X69.973
N205 G80
N210 G0 Z21.35
N220 M9
N225 G53 Z0.
N230 M30
Last edit: 09 Jan 2018 16:40 by JohnnyCNC.
- BigJohnT
10 Jan 2018 12:34 #104233
by BigJohnT
Yes, I own spyderstore.com.
When using R8 collets break up your G code for one tool, touch off then run that bit of code.
Yea that post processor is a mess, I'm still trying to understand Fusion 360. Which post processor did you pick?
For just simple stuff you might try my mill G code generator. gnipsel.com/files/mill-g-code/
JT
JT
- OT-CNC
- Thank you received: 75
14 Jan 2018 01:52 #104408
by OT-CNC
Replied by OT-CNC on topic Trying to run first metal part on new mill conversion
If you have a R8 spindle, look for the tormach tooling. That works well with smaller machines. I prefer their older style holders that are not designed for the tool changer if you can find them as they are a bit shorter.
- OT-CNC
14 Jan 2018 02:12 #104410
by OT-CNC
T2 M6 followed by T3 does not look correct to me. Not sure why the post would call out 2 tools.
- JohnnyCNC
14 Jan 2018 17:57 #104444
by JohnnyCNC
OT-CNC I do have R8 and I'm definitely getting some tool holders.
I did figure out what was wrong. In fusion the origin of the part was the bottom face of the part rather than the top. Since I was drilling a hold in 1/8 inch material when I touched off the part it thought that the tool was on the bottom face. Then when it went to drill it was drilling into the material by the amount of break through depth I had. I just made my first successful milling operation. The first attempt broke a 1/4 end mill because the default feed was too aggressive.
As far as the code calling out two tools I that was because the part had two different size holes in it. I was expecting to get prompted for the tool change and be able to touch off the second tool but it doesn't seem that how it works. For now I will stick with one tool per file until I either get tool holders and can populate the tool table or learn how to do what I thought I would be able to do if it can be done at all.
Much more learning to do.
- BigJohnT
17 Jan 2018 22:39 #104646
by BigJohnT
T is tool prepare and on some machines it is proper to call T right after M6 so the tool storage system can put the next tool in change position while the machine works.
JT
JT
- BigJohnT
17 Jan 2018 22:41 #104647
by BigJohnT
Time to create page: 0.121 seconds
