circles and shapes cut to small
- schmida
11 Jan 2018 07:11 #104272
by schmida
circles and shapes cut to small was created by schmida
Hi
Iam new to the forum. Hope someone can help me. Having recently finished building my CNC. All appeared OK until I measured my shapes. They are all smaller than designed appr 2mm regardless of size. The shape is correct.I use fusion 360. Have checked the design over a few times but all looks OK. I suspect it is to do with a setting in linuxcnc. Any suggestions would be welcome.
- ozzyrob
- Visitor
11 Jan 2018 07:43 #104273
by ozzyrob
Replied by ozzyrob on topic circles and shapes cut to small
Just off the top of my head...cutter size ?
- Thank you received: 1472
11 Jan 2018 13:28 #104291
Replied by Todd Zuercher on topic circles and shapes cut to small
Are you certain your scaling is correct?
Are you sure you are not loosing steps?
Do you have a backlash issue?
