Axis Custome menus
- dextaca
17 Jan 2018 18:49 #104641
by dextaca
Axis Custome menus was created by dextaca
Gents..
Wondering if someone wrote or can point me to some code on how to implement torque / velocity read out to be displyed in axis
Have Motenc with analogue input, would like to use it..
Was hoping to get the following for each axis.
- servo toque 0-300%
- speed RPM
- F-Error - current
Thank you kindly
Peter
- speed RPM
- F-Error - current
Thank you kindly
Peter
- BigJohnT
- Thank you received: 994
17 Jan 2018 22:44 #104648
by BigJohnT
Replied by BigJohnT on topic Axis Custome menus
First you would have to figure out how to get the two inputs from your drives into LinuxCNC then you could display them with a PyVCP panel. The following error can be found in HAL.
JT
JT
Time to create page: 0.063 seconds
