Rigid tapping requirements
  • JohnnyCNC
  • JohnnyCNC's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Jan 2018 02:08 #104825 by JohnnyCNC
Rigid tapping requirements was created by JohnnyCNC
Hi All,
I just converted a Sieg X3 mill using a 5i25+7i76 and I want to do rigid tapping. Right now I trying to figure out how to go about adding the hardware for the spindle signal pulses that I will need. What I have not been able to determine from reading the posts is what would be the ideal PPR for rigid tapping?
22 Jan 2018 02:16 #104826 by PCW
Replied by PCW on topic Rigid tapping requirements
You can basically use as high as you like, but you probably dont want much lower than 100 PPR
( 400 counts per turn quadrature ) for rigid tapping. For rigid tapping you need a quadrature encoder with an index.
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
22 Jan 2018 03:25 #104827 by JohnnyCNC
Replied by JohnnyCNC on topic Rigid tapping requirements
Thanks PCW.
I see a lot of 100,200,1024 encoders and I was thinking that more might not necessarily mean better I think I'll look for a 200 PPR quadrature with index.
Time to create page: 0.221 seconds
