PWM or 0-10V output from breakout board
- Motox737
26 Jan 2018 15:08 #105040
by Motox737
PWM or 0-10V output from breakout board was created by Motox737
Hi all,
I am trying to control my spindle speed with either PWM or 0-10V output on my bob. I used stepper config wizard. But my spindle speed does not change. I checked voltage on the board and on the PWM output it is reading mvolts and does not change. And on the 0-10v output it is just outputting 9.97v all the time. Here is a link to the bob I am using and I am also using a KBPB-125 spindle controler. Any help is appreciated.
www.ebay.com/itm/5-Axis-CNC-Interface-Ad...p2057872.m2749.l2649
- Thank you received: 5332
26 Jan 2018 16:05 - 26 Jan 2018 16:05 #105044
Replied by PCW on topic PWM or 0-10V output from breakout board
if the PWM output does not change, this suggests that there's a problem in your hal or ini file setup, possibly an
issue with pinout, polarity, and or scaling.
Can you post your hal and in files here?
Last edit: 26 Jan 2018 16:05 by PCW.
- Motox737
26 Jan 2018 16:55 #105049
by Motox737
Replied by Motox737 on topic PWM or 0-10V output from breakout board
Thanks for the reply. I will post them when I get home.
- eFalegname
- Thank you received: 30
26 Jan 2018 17:41 - 26 Jan 2018 17:43 #105052
by eFalegname
Replied by eFalegname on topic PWM or 0-10V output from breakout board
Thousand words:
and don't forget programm your inverter too
Last edit: 26 Jan 2018 17:43 by eFalegname.
- Motox737
26 Jan 2018 20:43 #105054
by Motox737
I'm not using a vfd.
- Motox737
26 Jan 2018 23:43 #105058
by Motox737
Here are my hal and ini files.
27 Jan 2018 00:52 #105060
It basically looks OK, do the step/dir outputs work?
That is is the parallel port /BOB working at all?
Can you measure the voltage at pin 1 of the parallel port when you set the spindle RPM to 500
and also verify that
pwmgen.0.value is 500
and
pwmgen.0.enable is true
When you do this
You can check these with halmeter or "watch"
and
When you do this
- Motox737
27 Jan 2018 00:55 #105061
by Motox737
yes my x and z axis' work as they should. i will go check the others you mentioned.
Time to create page: 0.136 seconds
