? RTAPI: ERROR: Unexpected realtime delay on task 1 ?
- d3z1b3l
02 Feb 2018 16:33 #105333
by d3z1b3l
? RTAPI: ERROR: Unexpected realtime delay on task 1 ? was created by d3z1b3l
Hello everybody,
I have an IBM Thinkpad 2668.
Pentium M
1.86 GHz
2GB of memory
On linuxcnc.org I downloaded the live image and installed it on the laptop.
I was able to set up my machine well on Linuxcnc and it also runs.
However, I have 2 problems:
1) Every now and then the program Linuxcnc simply hangs, then nothing works.
2) Almost always the following error message appears: "RTAPI: ERROR: Unexpected realtime delay on task 1. This Message will only display once per session. Run the Latency Test and resolve before continuing."
Latency test shows a value of approx. 6000 at idle.
I've tested all sorts of configuration values, no change.
can it be that these problems hang together?
There are no USB devices or other external hardware connected.
I did 5 tests without connecting the parallel port, also without a machine. -> 1x it stuck, 4x came the error message, once ran through without problems.
I hope you have a tip for me!
In a forum I read that one should install a smaller Linux with old computers and Linuxcnc manually install, that runs then better !?
Pentium M
1.86 GHz
2GB of memory
- Thank you received: 7470
08 Feb 2018 01:38 #105551
Replied by tommylight on topic ? RTAPI: ERROR: Unexpected realtime delay on task 1 ?
I had several IBM laptops with Linuxcnc, i still have a T42 running just fine as they always did, but mine where always T series or X series.
On all of them i have installed Ubuntu 10.04 Linuxcnc or Debian Wheezy Linuxcnc, so you should give them a try.
The following user(s) said Thank You: d3z1b3l
- d3z1b3l
08 Feb 2018 05:19 #105559
by d3z1b3l
Replied by d3z1b3l on topic ? RTAPI: ERROR: Unexpected realtime delay on task 1 ?
Thank you!
Now i got a cheap i5 PC with serial interface.
Someone told me, that Laptops often have Problems with the realtime Kernel.
Now it works perfectly without Problems!
Time to create page: 0.220 seconds
