- Thank you received: 22
7i76e Quick Setup
I've been doing a heap of searching here with no success.
I have found all this wiring stuff but nothing about the software side. I presume but cant find it written that none is needed?
Do I have to install the 7i76e in Linux somehow prior to all this connecting?
joel0407 wrote: Hey guys,
I used this guide, moved the jumper and set it to 10.10.10.10. like in tommylight's post
- noname2012
Good News: LinuxCNC has a wizard
Bad news: It's far from complete
1) LinuxCNC is a stand-alone operating system install it on a decent computer
2) Boot LinuxCNC open a terminal
3) run "pnconf" this will guide you through a configuration wizard making your 7i76e setup file
4) pnconf creates : "/home/yourUserName/linuxcnc/configs/yourConfigFileName/yourConfigFileName.ini"
5) also pnconf creates : "/home/yourUserName/linuxcnc/configs/yourConfigFileName/yourConfigFileName.hal"
6) make all the changes you can using pnconf then DON'T USE pnconf again, it will change things without you knowing
7) there is a ton of TWEAKING tweak the ini and hal files util you get it working -- have emergency stop switch ready
What kind of machine axis count ect did you make?
- noname2012
little_sparky wrote: Hi Guys,
I am just starting my own CNC Plasma build using Phil's new PlasmaC but when I try to create a pcnconf, I am unable to test my motors. Do you think this is because my IP address is still on the default setting or should this not matter?
Hybrid-servo motors or steppers?
Explain details -- 10.10.10.10 could be the issue...
Post pics of wiring to Mesa card... and upload .ini and .hal
