7i76e Quick Setup
8 years 2 months ago #116629 by tjones
Replied by tjones on topic 7i76e Quick Setup
I turned the board off, swapped the jumper, turn it back. Since then it has been off and on a couple of times.
The results of ip a:
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s7: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 00:1b:fc:06:e4:c7 brd ff:ff:ff:ff:ff:ff
3: wlx7cdd908b5432: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 2e:c5:56:cf:34:24 brd ff:ff:ff:ff:ff:ff
8 years 2 months ago #116630 by PCW
Replied by PCW on topic 7i76e Quick Setup
Right, so your local Ethernet is called enp0s7 not en01...
8 years 2 months ago #116631 by tjones
So I changed my ethernet to enp0s7 in the network setup file. I ran a ping for 10.10.10.10 and it came back as unreachable.
This is what my setup file looks like:
auto lo
iface lo inet loopback
auto enp0s7
iface enp0s7 inet static
address 10.10.10.1
netmask 255.255.255.0
This is the result of the last, ip a:
ip a
link/ether 1a:59:35:2a:aa:ac brd ff:ff:ff:ff:ff:ff
8 years 2 months ago #116632 by tjones
I realized I forgot to connect my power to the TB3 for the logic portion. I then cycled the power. I didn't immediately get anything from the ping and after about 10 minutes I tried it again and everything is working. Thank you for the help!
7 years 6 months ago #132473 by noname2012
Replied by noname2012 on topic 7i76e Quick Setup
Direct link to the newest iso files here:
www.linuxcnc.org/testing-stretch-rtpreempt/
6 years 11 months ago #150295 by little_sparky
Replied by little_sparky on topic 7i76e Quick Setup
Hi Guys,
I am just starting my own CNC Plasma build using Phil's new PlasmaC but when I try to create a pcnconf, I am unable to test my motors. Do you think this is because my IP address is still on the default setting or should this not matter?
Time to create page: 0.174 seconds
