SIeg X3 + 5i25 + 7i76 - Can't get speed control to respond.
  • JohnnyCNC
  • JohnnyCNC's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Feb 2018 12:13 #106613 by JohnnyCNC
It would be best to set up the spindle-enable output of the 7i76 to turn the spindle properly on and off. Is that an option?
Yes, that should be possible. The more I get a handle on the HAL the easier some of this is becoming. There are some terminals on the board for reset and I think enable that I should be able to connect to. The other thing I want to do is to detect if the motor faults and stop all motion. I have only seen it fault once or twice while running it manually. When it faults, a yellow LED comes on and then you have to go through the reset procedure to get the spindle to turn back on. I should be able to use the signal that turns on the LED to feed back to LinuxCNC.
Time to create page: 0.179 seconds
