How can I set diameter mode by default
- vmihalca
- Thank you received: 22
11 Feb 2018 10:54 #105740
by vmihalca
How can I set diameter mode by default was created by vmihalca
Hi guys,
Each time I start the machine an put a stock in the chuck, I need to set the work offsets and when I need to set the X coordinate, I always remember I forgot to run a G7 command to put in in diameter mode. Is there any way to default it to diameter mode for lathes?
Thanks,
Vasi
Thanks,
Vasi
- Clive S
- Thank you received: 486
11 Feb 2018 13:01 - 11 Feb 2018 13:04 #105741
by Clive S
Replied by Clive S on topic How can I set diameter mode by default
I think you could put it in the ini file add it to the start up code
This is just a sample:
[RS274NGC]
RS274NGC_STARTUP_CODE = G17 G21 G40 G43H0 G54 G64P0.5 G80 G90 G94 G97 M5 M9
[RS274NGC]
Last edit: 11 Feb 2018 13:04 by Clive S.
- vmihalca
12 Feb 2018 20:45 #105799
by vmihalca
Replied by vmihalca on topic How can I set diameter mode by default
Thanks, it worked!
Time to create page: 0.094 seconds
