3D printer with multiple extruders
8 years 8 months ago #105843 by RichJordan
Hi all,
I have spent a bit of time searching both the web and the forum for any indication of anyone trying this previously, if I've missed an obvious link then my apologies for starting a new topic.
I am exploring how best to operate 3 extruders on a 3D printer run by LinuxCNC. Probably the simplest thing I can see is to run each extruder as a separate axis, A, B and C. This way the positions for each of the axis are maintained as tool changes are executed. However, it seems that very few slicer programs can generate this kind of G code.
So looking for a more elegant solution I would like to be able to call a tool change (M6 Tn) and manage all extrusions via the A axis. I can see that behind the scenes, axis positions need to be stored and swapped to be available for the A axis. Also stepper IO needs to be rerouted to a different stepper driver. Can this be done within LinuxCNC? If so how do I go about it.
8 years 8 months ago #106002 by calvin.d
if you have a driver for each extruder, you could make use relays to switch the step and directions lines, control it with GPIO pins and just set up your tool change to push a pin high to enable step and direction to each motor. If you are comfortable with electronics you could do this with a handful of transistors. I want to do a similar thing in the future as well, have you thought about how you are going to do your temperature control ?
what are you using for general hardware ? Parallel port or something in the MESA family
Calvin
8 years 8 months ago #106101 by RichJordan
Hi Calvin,
Thanks for your reply. I like your suggestion about switching drivers with relays or transistors. This is how I hoped to achieve this too. The bit I can't figure out yet is how to store the position of extruder 1 and load the position of extruder 2 into the A axis position register. The reason for this is my gear uses syringes for printing food which have finite volumes that I need to keep track of during the print.
Currently I'm using a parallel port as I have to supply 3 of these machines, but if they become too limited I have a MESA 5i25 (or whichever is their super parallel port board).
8 years 8 months ago #106105 by Grotius
@RichJordan,
I have an idea. How is does your program output looks like?
Do you need to store postion's for each extruder? Or is it just stop the food supply by motor?
And how is your program procedure with the 3 extruders?
I had a similar project, and had a nice solution for it.
The following user(s) said Thank You: RichJordan
8 years 8 months ago #106110 by rodw
Do your extruders operate one at a time or can you operate them in unison? I have some ideas to do it without external hardware. Your offsets could be managed by the tool table and you could swap the stepgen outputs to different stepper motors based on the selected tool.
8 years 8 months ago #106112 by tommylight
rodw wrote: Your offsets could be managed by the tool table and you could swap the stepgen outputs to different stepper motors based on the selected tool.
That is the way to go, or do a search on the forum as some members here have routers with more than one spindle, and technicaly that is the same thing you need.
Time to create page: 0.193 seconds
