- Thank you received: 3
Multiple reference positions
- shipmodeller
- Topic Author
8 years 8 months ago #106078
by shipmodeller
Multiple reference positions was created by shipmodeller
I do wood inlays on my CNC machine. There is a long time between jobs where I am waiting for glue to dry before the next machining job. All my jobs require XY to be 0,0. So, when I can put multiple pieces down on the bed. When I zero the first one ( XYZ ) I execute the gcode and the last step, it goes home. I write down on paper what the XYZ numbers were from home position to the 1st piece. I then go to the 2nd piece, write down the offset XYZ from the 1st one..Write that down. So, it might be +10.32, -5.34. When that job is done, I need to reference back to the 1st one so I can do the nth machining operation, so in my case.. I would then do an offset of -10.32, +5.34, which gets me back to the 1st position, and then zero the axis. Do the code. This is a pain, for two pieces, but sometimes I have 10 or more pieces being done at the same time. It would be nice to either have a dropdown list of points, then a button tell me to go there.. I can code, but not sure how to deal with this ...Is there something out there that can do this already? Thanks
8 years 8 months ago #106082
by Tchefter
Replied by Tchefter on topic Multiple reference positions
Hi, is this everytime the same Position?
If so, you can put some MDI-Commands to the HALUI Section in your machine.ini and map this to a Button with Pyvcp Panel.
Greetings
Greetings
- shipmodeller
- Topic Author
8 years 8 months ago #106084
by shipmodeller
Replied by shipmodeller on topic Multiple reference positions
No, it is not... each setup, because of size, is different... I generally never do the same inlays twice.. but to speed up time, I usually have multiple inlays on the table at the same time. So, this would have to be a dynamic solution.. I.E. Press a button, assign current X Y ( possibly z ) to a label.. add to list .. move on. Then list ( or toggle though a list , and execute.. ) I realize there are limitations to what I can do dynamically. And yes, you are right, if it was repetitive, yours would be what I would have done.. but I need a dynamic solution, not a static one,.. Thanks
8 years 8 months ago - 8 years 8 months ago #106085
by Tchefter
So you can do this also in MDI Mode, or not? (Toogle with F3 / F5)
Every Position you have to write one time will save in this List, also when your PC is off...
Last edit: 8 years 8 months ago by Tchefter.
The following user(s) said Thank You: shipmodeller
8 years 8 months ago #106087
by FariaAl
Replied by FariaAl on topic Multiple reference positions
have you looked here?
i have similar situations once in a while and this works for me
Coordinate Systems
Coordinate Systems
The following user(s) said Thank You: Tchefter, shipmodeller
- shipmodeller
- Topic Author
8 years 8 months ago #106089
by shipmodeller
Yes, duh! That should do the trick... Not as neat as a button, yes... that will work thanks!
