Estimated time to completion via Python
- AtinA
20 Feb 2018 20:15 #106251
by AtinA
Estimated time to completion via Python was created by AtinA
Hi.
I noticed that we can get the time to completion by going to File>properties and get the estimated run time. Is there a way to get this data pythonically?
thanks.
thanks.
- Thank you received: 2173
20 Feb 2018 23:15 #106258
Replied by cmorley on topic Estimated time to completion via Python
While I can't answer your question definitively (Though I'm sure the answer is no),
But in most cases the estimations are not worth the effort to get them.
Such things as axes accelerations and on-the-fly motion profile adjustments make reasonably accurate estimations very difficult.
But:
I'm sure i remember someone else working on a semi solution here on the forum - you might try the search.
Chris M
But:
Chris M
- AtinA
20 Feb 2018 23:20 #106260
by AtinA
Replied by AtinA on topic Estimated time to completion via Python
I had read on this forum that the times estimated are off by several factors. Turns out sometimes the estimated runtime doesn't even show up in the file properties!
I haven't come across a "semi solution" yet. Please let me know if you find something.
21 Feb 2018 00:21 #106261
My memory seems to be not quite right.. google says it was about recording actual time of machining.
forum.linuxcnc.org/38-general-linuxcnc-q...perties?limitstart=0
Time to create page: 0.192 seconds
