- Thank you received: 127
Simulator
- tecno
8 years 8 months ago #106689
by tecno
Simulator was created by tecno
Is it possible to take my working lathe INI + HAL and make this work in Simulator?
Would like to test out GUI's in my laptop
Cheers
Bengt
Cheers
Bengt
- tecno
8 years 8 months ago #106692
by tecno
Replied by tecno on topic Simulator
Axis in lathe mode with Lathe macros is what I want to play around with for starters.
- Thank you received: 1480
8 years 8 months ago #106698
Replied by Todd Zuercher on topic Simulator
Here is what I would try to do, first load one of the sim lathe example configs, the one that is closest to what you might like to do. Such as sim/axis/ngcgui/ngcgui_lathe.
Then copy your ini file to the config directory for that sim, and edit your ini file so that it calls the same hal file(s) as the ini for the sim. You will also need to add any additional display lines, such as the ones that call up VCPs, simply copy those lines from the sim ini to your new ini. You might still find you need to make further edits to your ini or the hal files but the above should get you close.
- tecno
8 years 8 months ago - 8 years 8 months ago #106734
by tecno
Last edit: 8 years 8 months ago by tecno.
8 years 8 months ago #106741
Ah, NativeCAM, I have not played with that. It may have more ini requirements than an ordinary config.
Could you post the ini file you are trying to use, and the one for the original sim config you are trying to graft onto.
- tecno
8 years 8 months ago #106743
by tecno
I made a new setup via stepconfig so it is only this INI
Time to create page: 2.535 seconds
