Not able to start LinuxCNC
  • electrophile
  • Topic Author
  • New Member
  • New Member
8 years 7 months ago #106897 by electrophile
Not able to start LinuxCNC was created by electrophile
I'm a newbie to the world of LinuxCNC and I recently built a 3-axis machine of my own design and I'm trying to configure LinuxCNC to work with the Toshiba 6600 drivers. I stepped through the Stepconf wizard and created a machine profile as well. However, when I try and start LinuxCNC with this machine profile (using the shortcut on the desktop) I get the following error. (as attached). What am I missing?
File Name: linuxcncerror.txt
File Size:57.35 KB
  • electrophile
  • Topic Author
  • New Member
  • New Member
8 years 7 months ago - 8 years 7 months ago #106899 by electrophile
Replied by electrophile on topic Not able to start LinuxCNC
OK I was able to see the UI now. Apparently no parallel port was defined or it didn't find it in the location that I thought it was located at. I have a PCI card that is the parallel port and when I type in 'lspci -v' at the terminal I see this:
03:00.0 Serial controller: Device 1c00:3250 (rev 10) (prog-if 05 [16850]) Subsystem: Device 1c00:3250 Flags: fast devsel, IRQ 18 I/O ports at d800 [size=256] Memory at faff8000 (32-bit, prefetchable) [size=32K] I/O ports at dc00 [size=4] Expansion ROM at fbef0000 [disabled] [size=32K] Capabilities: <access denied>
Does this mean the address is 1c00 or d800 or dc00 (I had entered dc00 in the first instance and that cause the error mentioned in the earlier post).
Last edit: 8 years 7 months ago by electrophile.
  • Moderator
  • Moderator
8 years 7 months ago #106936 by tommylight
The following user(s) said Thank You: electrophile
Time to create page: 0.056 seconds
