Need Help
8 years 7 months ago #106901 by Vig
Need Help was created by Vig
Good afternoon.
I'm trying to learn Linuxcnc and I ran into a problem.
I adjust through stepconf, I expose the necessary parameters,
I press to check the axis - the axis scores exactly twice as much.
If I put the pitch of the screw half as much, then everything is fine.
It is not possible to make mistakes in the settings, everything is simple there.
Sorry, I'm writing through Google translate
8 years 7 months ago #106902 by Mike_Eitel
Replied by Mike_Eitel on topic Need Help
If you found a fix ..what is your problem?
8 years 7 months ago #106903 by Vig
Replied by Vig on topic Need Help
If this is a bug in the program, then the wrong data will be written to the initial value
8 years 7 months ago #106998 by andypugh
Replied by andypugh on topic Need Help
Vig wrote: I press to check the axis - the axis scores exactly twice as much.
This sounds like the drive microstepping is not set to what you think it is.
(And many drives out there are actually wrongly documented).
Time to create page: 0.266 seconds
