Hello I need lnux cnc to machine in -x and -y .
  • mcultrara
  • Topic Author
  • New Member
  • New Member
8 years 7 months ago #106915 by mcultrara
I have written short g code to make a U shape but I am setting the x and y home in the center and G02 around half way. linux cnc says it can't how to make.
G17
G90
G01 X0.0 Y0.0 Z0.0 F4
G01 X-0.25 Y0.4
G01 Z-0.1 F2
G01 X-0.25 Y-0.3
G04 P1
G01 X0.25 Y-0.3
G01 X0.25 Y0.4
G04 P1
G01 X0.25 Y0.0
G02 X-0.25 Y0.0 I-0.25 J0.0
G01 X-0.25 Y.1
G04 P1
G01 X-0.25 Y0.0
G03 X0.25 Y0.0 10.25 J0.0
G01 X0.25 Y0.1
G04 P1
G01 Z0.0 F4
G01 X0.0 Y0.0 Z0.0
M02
8 years 7 months ago #106929 by Todd Zuercher
Replied by Todd Zuercher on topic Hello I need lnux cnc to machine in -x and -y .
Linuxcnc says it can't what?
Does it say that the file exceeds the limits? If so, it is because you are misusing/don't understand homing. Sounds like you are using homing for the job that work coordinates are intended for.
8 years 7 months ago #107000 by andypugh
Jog your machine to the point that you want to be the 0,0 of your part. Then use the "touch off" button to set X and Y to zero. Then your G code should run.
Time to create page: 0.072 seconds
