Huangyang Analog control
8 years 7 months ago #107036 by andypugh
Replied by andypugh on topic Huangyang Analog control
It isn't quite that simple, I don't think, with the 7i76. The reason is that the enable output is set when the analogue output is enabled.
So you do rather need to configure the VFD to use "on" and "reverse" rather than "fwd" "reverse" mode.
If this is impossible then you need to use a anoither GPIO output, or do something cunning with relays.
8 years 7 months ago #107042 by Mike_Eitel
Replied by Mike_Eitel on topic Huangyang Analog control
Have not jet programed my vfd but read that there are more then only two inputs and over 10 choises for each how vfd reacts. F.x. i will change my first there to enable/direction/estop.
8 years 7 months ago #107072 by timmert
Replied by timmert on topic Huangyang Analog control
Got it working with some help of another forum
To summarize the answer I received:
ENA+ connected to FOR
DIR+ connected to REV
ENA- and DIR- connected to DCM
on vfd:
PD044 to 1
PD045 to 5
It works perfect
But the scale is off
When I enter a M3 S300 it spins 2000RPM
But when I enter M3 S1 it also spins 2000RPM
I used a 12v power supply
Do I need to configure something else?
It seems it will only run at max rpm.
Base and Max freq is set to 50Hz
8 years 7 months ago #107073 by andypugh
What is ...7i76.0...scalemax (As you can tell, I have forgotten the actual pin name)
That needs to be set to the maximum speed of the spindle.
8 years 7 months ago #107074 by timmert
Spindle runs around 2990RPM at 75hz
I attached my HAL file
8 years 7 months ago #107075 by andypugh
It's these:
setp hm2_5i25.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
What values do you have in the INI for those parameters?
Time to create page: 0.160 seconds
