Huangyang Analog control
8 years 7 months ago #106958 by timmert
Replied by timmert on topic Huangyang Analog control
I don't know what to do with step/dir?
I had a Danfoss VFD before with 0-10v
And only connected the TB4 Spindle stuff to my VFD.
Where do I connect the DIR- DIR+ and EN- EN+ to my VFD?
8 years 7 months ago #106961 by Mike_Eitel
Replied by Mike_Eitel on topic Huangyang Analog control
Sorry not step/dir but ena/dir
8 years 7 months ago #106966 by raglanlittlejohn
Looking at the 7i76 manual, the speed control looks the same as the 7i78. My vfd an NF-9000 puts 10v+ve on the terminal marked 10v, and 0v on ACOM. I would check the volts on those connections.
On the vfd I connect FWD to DCOM for forward, and REV to DCOM for reverse. I would start by getting forward/reverse working with the correct terminals for your vfd ie just use a switch, (take care not to short anything out). When you have this working, you can look into whats needed from the 7i76. (I spent several hours trying to find a fault on the vfd, when the problem was an intermittent fault on one of the relays)
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
8 years 7 months ago #107024 by timmert
I do have a FOR and REV on my VFD.
But how do I connect it to the 7i76?
FOR to EN+
or REV to EN+
8 years 7 months ago #107026 by Mike_Eitel
First you must decide how you want to work!
Either you go with enable and direction signals or with forward and reverse signals.
Have a look with of the two ways is presented at your mesa output pins. Than connect the two to your vfd. At last change with P parameter the behaviour of these two vfd input pins. Done
8 years 7 months ago #107035 by raglanlittlejohn
The motion component has a motion.spindle-forward pin, and a motion.spindle-reverse pin. Run your config. Do Machine, Show Hal Configuration, then watch those pins while you select spindle forward/reverse in manual control. If they come on, they just need mapping to the appropriate output. There is also a motion spindle on pin, mine comes on for forward or reverse.
Time to create page: 0.205 seconds
