Internationalization: The Spanish affair
7 years 10 months ago #122328 by dgarrett
The only difference is the es.po file.
post the es.po file
post the output of linuxcnc_info
7 years 10 months ago #122329 by andypugh
Note: Using LXRT realtime
This means (I think) that you have not configured (./configure --with-realtime=....) for the correct kernel.
This _might_ be the problem, it might not be related to the translation.
7 years 10 months ago - 7 years 10 months ago #122330 by abu
Thanks Dewey.
I'm going to upload the .po file to a server. I will put the link when the upload ends.
My info file....
The file: /tmp/linuxcnc.info
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
VIEWER=gedit
Date: jue dic 13 00:32:37 CET 2018
UTC Date: mié dic 12 23:32:37 UTC 2018
this program: /home/pulvimax/linuxcnc-dev/scripts/linuxcnc_info
uptime: 00:32:37 up 15:53, 2 users, load average: 0,82, 0,72, 0,68
lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy
which linuxcnc: /home/pulvimax/linuxcnc-dev/scripts/linuxcnc
pwd: /home/pulvimax/linuxcnc-dev/scripts
USER: pulvimax
LOGNAME: pulvimax
HOME: /home/pulvimax
EDITOR:
VISUAL:
LANGUAGE:
TERM: xterm
COLORTERM: Terminal
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 2048x768 pixels (642x241 millimeters)
PATH: /home/pulvimax/linuxcnc-dev/scripts:/home/pulvimax/linuxcnc-dev/bin:/home/pulvimax/linuxcnc-dev/bin:/home/pulvimax/linuxcnc-dev/scripts:/home/pulvimax/linuxcnc-dev/tcl:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: vento
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
machine -m: i686
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=3211c8f8-95ad-464a-a1bb-7506f3eaef3b ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
model name: AMD Phenom(tm) 8650 Triple-Core Processor
cores: 3
cpu MHz: 2299.936
parport: 0378-037a : parport0 037b-037f : parport0 d800-d802 : parport2 dc00-dc02 : parport1
serial:
Versions:
gcc: gcc (Debian 4.7.2-5) 4.7.2
python: Python 2.7.3
git: git version 1.7.10.4
tcl: 8.5
tk: 8.5
glade: not_in_PATH
glade-gtk2: glade3 3.8.0
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /home/pulvimax/linuxcnc-dev/scripts/realtime
RTS: uspace
HALLIB_DIR: /home/pulvimax/linuxcnc-dev/lib/hallib
Last edit: 7 years 10 months ago by abu.
7 years 10 months ago #122331 by abu
Hi Andy.
My command is
./configure --with-realtime=uspace
or with documentation:
./configure --with-realtime=uspace --enable-build-documentation
7 years 10 months ago #122337 by andypugh
That's interesting, as the output definitely says LXRT. (Which appears to be an unexpected default)
Could you try a re-config and re-build?
(This is the only time that I have seen LXRT come up)
sourceforge.net/p/emc/mailman/message/36479905/
7 years 10 months ago #122338 by dgarrett
with this pre-built kernel:
use without options:
$ cd the_src_directory $ ./configure
(as andy noted, not sure it has anything to do with
internationalization)
i think you will not see the LXRT message if configured as above
Time to create page: 0.058 seconds
