Repeat command for cnc router
- wooden.art
14 Mar 2018 20:55 #107357
by wooden.art
Repeat command for cnc router was created by wooden.art
Hello Dears,
I need your kind help!
I am using Linuxcnc version 2.6.13 to operate my cnc router machine for wood working but my question is how to repeat the same program for several time automaticly?
My machine is using stepper motor for x,y&z axis
And driver for cutting head.
Appreciate your kind response.
- Thank you received: 4652
15 Mar 2018 11:46 #107369
Replied by andypugh on topic Repeat command for cnc router
You can put an O nnn REPEAT command in the G-code.
linuxcnc.org/docs/2.7/html/gcode/o-code.html#ocode:repeat
The following user(s) said Thank You: wooden.art
Time to create page: 0.063 seconds
