mesa 7i47s step and direction pulses
- mpvriens
16 Mar 2018 12:15 #107418
by mpvriens
mesa 7i47s step and direction pulses was created by mpvriens
When inverting timing on the mesa 7i47s, we get a step/ dir puls that is not recognized by the driver .
How to invert timing and get a normal puls signal.
16 Mar 2018 13:48 #107427
Replied by andypugh on topic mesa 7i47s step and direction pulses
What do you mean by "inverting timing" ?
- Thank you received: 5330
16 Mar 2018 14:03 - 16 Mar 2018 14:05 #107429
Replied by PCW on topic mesa 7i47s step and direction pulses
The 7I47 has differential outputs so if the output is not the correct polarity you chose the opposite polarity
( - instead of + or vice versa ) output, or swap + and - outputs if you are using differential signalling.
You can also change the polarity in the hal file but this is usually not necessary
Note the by far the most common reason we have seen for step/dir outputs to not work with drives
is too short timings.
( People commonly select the drives _minimum_ step length as the step generators step length which is of course on the edge of not working at all )
Last edit: 16 Mar 2018 14:05 by PCW.
- mpvriens
18 Mar 2018 09:02 #107485
by mpvriens
Replied by mpvriens on topic mesa 7i47s step and direction pulses
THKS timing was too short
Marius
Marius
Time to create page: 0.142 seconds
