- Thank you received: 56
MPG reversing Y axis rotation to reflect manual mill
- OT-CNC
- Topic Author
8 years 7 months ago #107505
by OT-CNC
MPG reversing Y axis rotation to reflect manual mill was created by OT-CNC
I have a MPG jog wheel up and running and noticed that even though it's configured correctly the rotation of the y is incorrect when comparing it to a manual mill. I'd like to reverse the y axis only.
# ---jogwheel signals to mesa encoder - shared MPG---
setp axis.x.jog-vel-mode 1
setp axis.y.jog-vel-mode 1
setp axis.z.jog-vel-mode 1
net scale1 mux4.0.sel0 <= hm2_5i25.0.7i77.0.0.input-22
net scale2 mux4.0.sel1 <= hm2_5i25.0.7i77.0.0.input-23
setp mux4.0.in0 0.0000001
setp mux4.0.in1 0.00001
setp mux4.0.in2 0.000001
setp mux4.0.in3 0.000015
net mpg-out ilowpass.0.in <= hm2_5i25.0.7i77.0.0.enc0.count
#### jog enable with 4 selctor sw, 2 inputs, 4 out logic ####
#a=00
#x=01
# y=10
# z=11
#loadrt and2 count=4
addf and2.4 servo-thread
addf and2.5 servo-thread
addf and2.6 servo-thread
addf and2.7 servo-thread
net input1-not <= hm2_5i25.0.7i77.0.0.input-20-not => and2.4.in0
net input2-not <= hm2_5i25.0.7i77.0.0.input-21-not => and2.4.in1
net mpg-a <= and2.4.out => axis.a.jog-enable
net input1-not => and2.5.in0
net input2 <= hm2_5i25.0.7i77.0.0.input-21 => and2.5.in1
net mpg-x <= and2.5.out => axis.x.jog-enable
net input1 <= hm2_5i25.0.7i77.0.0.input-20 => and2.6.in0
net input2-not => and2.6.in1
net mpg-y <= and2.6.out => axis.y.jog-enable
net input1 => and2.7.in0
net input2 => and2.7.in1
net mpg-z <= and2.7.out => axis.z.jog-enable
#### end of jog enable selector switch ######
###continuation of mpg jog wheel ####
net mpg-scale <= mux4.0.out
net mpg-scale => axis.x.jog-scale
net mpg-scale => axis.y.jog-scale
net mpg-scale => axis.z.jog-scale
net encoder-counts <= ilowpass.0.out
net encoder-counts => axis.x.jog-counts
net encoder-counts => axis.y.jog-counts
net encoder-counts => axis.z.jog-counts
#a=00
#x=01
# y=10
# z=11
- Mike_Eitel
- Thank you received: 144
8 years 7 months ago #107511
by Mike_Eitel
Replied by Mike_Eitel on topic MPG reversing Y axis rotation to reflect manual mill
Not sure if that works , but would try to mutiply Y scale by -1.0
The following user(s) said Thank You: OT-CNC
- Thank you received: 4006
8 years 7 months ago - 8 years 7 months ago #107539
Replied by andypugh on topic MPG reversing Y axis rotation to reflect manual mill
linuxcnc.org/docs/2.7/html/man/man9/scale.9.html
loadrt scale names=y-invert
addf y-invert servo-thread
setp y-invert.gain -1
#net mpg-scale => axis.y.jog-scale
net mpg-scale y-invert.in
net mpg-scale-inverted y-invert.out => axis.y.jog-scale
Last edit: 8 years 7 months ago by andypugh.
- OT-CNC
- Topic Author
8 years 7 months ago #107670
by OT-CNC
Replied by OT-CNC on topic MPG reversing Y axis rotation to reflect manual mill
Thanks guys for the help! It's funny how long I can get hung up just increasing the count on a component to get it to work LOL.
I couldn't get the syntax correct when the names is listed. So I ditched it. How do you typically increase the count when the names is used?? In this case scale was used for the spindle.
I got this to work:
#loadrt scale count=1 names=scale.spindle
loadrt scale count=2
addf scale.0 servo-thread
addf scale.1 servo-thread
net mpg-scale => axis.a.jog-scale
##invert y mpg rotation ##
setp scale.1.gain -1
net mpg-scale scale.1.in
net mpg-scale-invert scale.1.out => axis.y.jog-scale
I got this to work:
8 years 7 months ago #107678
You can do it by using HAL TWOPASS:
linuxcnc.org/docs/2.7/html/hal/twopass.html#cha:hal-twopass
In your case, to keep things simple, one loadrt might need to mimic the pin name given if names is not used, ie
loadrt scale names=scale.0
Then in another HAL file you could use
loadrt scale names=y-scale
I suspect that you might not be allowed any spaces in a mutliple-loadrt line such as
loadrt scale names=scale.0,y-scale
OT-CNC wrote: How do you typically increase the count when the names is used??
Time to create page: 0.135 seconds
