Mapping input from Logitech joypad to hal show failure
  • jensor
  • jensor's Avatar Topic Author
  • Premium Member
  • Premium Member
21 Mar 2018 13:02 #107659 by jensor
After successfully finding the Logitech F310, and getting Axis running, then going into hal configuration I see all the hal assigned inputs.
However, operating the buttons on the Logitech gives no response on any of the hal inputs in hal watch.
Never had this problem with the original el-cheapo joypad that failed mechanically.
I'm running Axis 2.7.11
Anyone with ideas to help would be appreciated.
21 Mar 2018 13:35 #107662 by andypugh
I had a joypad that needed a button pressing before it would work in HAL.
Something to do with having two compatibility modes or something.
  • jensor
  • Premium Member
  • Premium Member
21 Mar 2018 15:17 #107668 by jensor
The logitech has outputs when plugged into my MacBook Pro. I found a 2 position switch on the bottom that acted as though it turned the device off in one position. I've tried both positions on the linuxcnc.
On top there is a "mode" switch that toggles between the Hat button and Joy button functions.
  • jensor
  • Premium Member
  • Premium Member
21 Mar 2018 16:32 #107677 by jensor
Success! 2 position switch on bottom had to be in the X position. less /proc/bus/input/devices yielded name as X-Box.
Now getting response in hal-show. Discovered button on top labeled mode has no output. It apparently toggles the output of the joy stick and left Hat button.
Time to create page: 0.087 seconds
