Near
- jensor
- Thank you received: 4
25 Mar 2018 22:07 #107854
by jensor
Near was created by jensor
Where do I find detailed instructions on using the "near" component of hal. I see it used in examples but unable to find how to use it.
- Thank you received: 5321
25 Mar 2018 22:24 #107857
Replied by PCW on topic Near
Have you read the (rather terse) manual page?
man near
man near
- Thank you received: 4652
25 Mar 2018 23:49 - 26 Mar 2018 10:22 #107862
Replied by andypugh on topic Near
Terse is the word, isn't it?
linuxcnc.org/docs/2.7/html/man/man9/near.9.html
You need to load the componentthen add it to a thread so that it gets updated every servo cycleThen connect the inputs and outputsand set the tolerance and comparison value
The comparison value can be supplied by another HAL pin if required.
loadrt near count=1addf near.0 servo-threadnet some_signal_name one.of-the.hal.pins near.0.in
net another_signal_name near.0.out another.hal.pinsetp near.0.in2 100
setp near.0.difference 1The comparison value can be supplied by another HAL pin if required.
Last edit: 26 Mar 2018 10:22 by andypugh. Reason: formatting error
- jensor
25 Mar 2018 23:52 #107863
by jensor
Replied by jensor on topic Near
Thanks for that info. That does work however it is more convenient in my situation to be able to access it on line. Is that possible. My linux machine is on the bridgeport in my shop, while I'm sitting here in my kitchen on my laptop.
Is there a way of getting to this information online?
- dgarrett
- Thank you received: 297
25 Mar 2018 23:55 - 25 Mar 2018 23:59 #107865
by dgarrett
Replied by dgarrett on topic Near
Docs (current branch): linuxcnc.org/docs/2.7/html/
Scroll down for the man pages
Example: linuxcnc.org/docs/2.7/html/man/man9/near.9.html
On a machine with LinuxCNC installed, you can always use the command line:
$ man near
Last edit: 25 Mar 2018 23:59 by dgarrett.
26 Mar 2018 00:52 #107871
If you are lazy and forgetful like me you can also goggle:
man linuxcnc near
man linuxcnc near
- jensor
26 Mar 2018 11:02 #107895
by jensor
Yes, that finds it, however
linuxcnc haui near
doesn't find it for me.
It seems like you need man in the search data.
Now I have bookmarked
linuxcnc haui near
- Thank you received: 1472
26 Mar 2018 14:30 #107902
Replied by Todd Zuercher on topic Near
You don't need "man" in the google search "linuxcnc near" or 'linuxcnc near.9" are enough to bring up the man page as the first couple hits. (At least for me, but maybe Google knows me too well.)
