Tool Touch Off
- Wirewrap
30 Mar 2018 17:27 #108114
by Wirewrap
Tool Touch Off was created by Wirewrap
There is a new button in AXIS that I have not seen before, "Tool Touch Off" below tha familiar "Touch Off" button.
What does it do?
What does it do?
- Thank you received: 1472
30 Mar 2018 18:46 #108116
Replied by Todd Zuercher on topic Tool Touch Off
In older versions of Linuxcnc there was only one touch off button. Then you had to choose the work coordinate system or tool from the sub menu. The newer versions separated the tool part to its own separate button, otherwise functionality is the same.
- Thank you received: 4652
30 Mar 2018 20:18 #108131
Replied by andypugh on topic Tool Touch Off
it was to save people like me from making the mistake of touching off the coordinate system rather than the tool because we forgot to operate the drop-down selector.
I did it so often that I actually asked for the new button.
- Wirewrap
30 Mar 2018 20:45 #108137
by Wirewrap
Replied by Wirewrap on topic Tool Touch Off
Obviously I am missing in basic understanding here.
What variable is changing when I do "Tool Touch off" vs doing "Plain Touch off"?
30 Mar 2018 21:12 #108144
"plain" touch off changes the axis offsets.
Tool touch-off changes the tool table offsets.
The following user(s) said Thank You: Wirewrap
30 Mar 2018 21:15 #108145
One changes the work coordinates (G54,G55...), the other changes the tool offsets in the tool table (G43Hn, G41Dn...).
Time to create page: 0.178 seconds
