Loosing the keyboard after a cut
  • Gr8funTargets
  • Topic Author
  • New Member
  • New Member
8 years 6 months ago #108568 by Gr8funTargets
Loosing the keyboard after a cut was created by Gr8funTargets
Hi All
I've been using LinuxCNC for 4+ years or so now and just completed an upgrade after a minor HW disaster. Everything is back to normal but "normal" includes loosing the keyboard after a couple of pierces\cuts.
It's no big deal as I do prototyping only with this machine, I just unplug it and re-plug and all is good, but wondered if anyone else had experienced this and if so did they have a solution to remedy it?
I guess it is going to be some sort of electrical interference from the plasma arc.. . but what needs shielding?
Any ideas chaps?
Thanks in advance
Danny
  • Moderator
  • Moderator
8 years 6 months ago #108679 by tommylight
Replied by tommylight on topic Loosing the keyboard after a cut
Check grounding, move keyboard and mouse cables as far as possible from the plasma cutter, change the keyboard as new ones have bad shielding,put cables through metal tubes.
8 years 6 months ago #108747 by andypugh
Replied by andypugh on topic Loosing the keyboard after a cut
Have a look in dmesg, if you see the USB keyboard being lost and reconnected every few seconds then it is probably RFI of some sort.
Is it a wired or wireless keyboard?
Time to create page: 0.069 seconds
