Radius to end of arc error
8 years 6 months ago #108891 by aosowski
Hi everyone, I've come across an error that I have not been able to figure out.
The error reads
"Radius to end of arc differs from radius to start: start=(X7.5183,Y5.6580) center=(X7.6296,Y5.6219)r1=0.1171 r2=0.0753 abs err=0.04179 rel_err=35.6966%"
I have adjusted the amount of decimal places in the post processor from 4 to 9. This ended up fixing this error on a previous file but did not work for this file. I have also tried adjusting the CENTER_ARC_RADIUS_TOLERANCE_INCH variable in the INI file. I have also made sure the tool table offsets are correct.
Any suggestions to help fix this issue would be appreciated! Thanks!
8 years 6 months ago #108892 by DanMN
Replied by DanMN on topic Radius to end of arc error
I encountered this in Fusion360 (in some cases) when using helical moves. In my case, believe it's something in the way F360 constructs the compound moves of a tool path with a continuously varying radius combined with a smooth ramp-down. The two ways I've worked around it are:
1. Turn off Allow Helical Moves in the F360 post processor options
2. Turn of Lead In and Lead Out in the CAM>Operation>Linking options.
If you're not using F360, I'm not sure if this helps. I know this isn't the ideal solution to the problem, but it can get you back to work. I haven't broken any tools with this approach...yet. I have been distracted by other priorities, so I haven't had time to dig into a more appropriate fix. It could be a bug, but I don't know enough to make that claim.
8 years 6 months ago #108893 by aosowski
Replied by aosowski on topic Radius to end of arc error
Hi Dan! I am not using Fusion for this project, but I will keep that in mind for future projects. I am currently using vectric aspire. I have been able to get two lines further by changing G90 to G90.1 at the beginning of the file, but am still getting the error.
8 years 6 months ago #108911 by tommylight
That happens when you try to run a arc that is a segment of a radius, or if you have tool compensation and the selected tool is thicker than the smallest radius in the gcode.
8 years 6 months ago #108925 by aosowski
An update: I ended up editing the post processor file in aspire. I changed the arc parameters from I J to R. This seemed to fix the issue.
Time to create page: 0.063 seconds
