I need for help for config my cnc
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
18 Apr 2018 11:05 #109239 by ozzyrob
Replied by ozzyrob on topic I need for help for config my cnc
Try changing
loadrt sim_parport names=parport.0
Read about sim_parport here
to
loadrt hal_parport cfg="0x378"
if your Parallel port is at 0x378
For more info www.inet.home/linuxcnc/hal/parallel-port.html
  • mitakata_net
  • mitakata_net's Avatar Topic Author
  • New Member
  • New Member
18 Apr 2018 11:20 #109240 by mitakata_net
Replied by mitakata_net on topic I need for help for config my cnc
link from post, does not load :(
18 Apr 2018 11:34 - 18 Apr 2018 11:35 #109241 by Clive S
Replied by Clive S on topic I need for help for config my cnc
Yes you have loaded a sim version with stepconf So if you have not changed any files, run stepconf again with your config and un-check the box " Create Simulated Hardware" on the first page " then you will see the PP option
Last edit: 18 Apr 2018 11:35 by Clive S.
  • mitakata_net
  • New Member
  • New Member
18 Apr 2018 12:05 #109243 by mitakata_net
Thanks to all who gave advice and helped me!
My mistake was that in the initial steppe window I put a teak on "Create Simulated Hardware", just like # Clive s said.
I made the change and now LinuxCNC started managing my CNC.
Thanks again for the help, I am very happy :)
18 Apr 2018 12:29 #109246 by Clive S
Glad you got it sorted, it was ozzyrob that spotted it
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
18 Apr 2018 22:40 #109278 by ozzyrob
Sorry was looking at my local server.........must remember to put brain in gear, just for completeness links fixed
linuxcnc.org/docs/2.7/html/man/man9/sim_parport.9.html
linuxcnc.org/docs/2.7/html/hal/parallel-port.html
  • mitakata_net
  • New Member
  • New Member
19 Apr 2018 07:49 #109284 by mitakata_net
Thank you very much!
Everything works perfectly :)
Time to create page: 0.137 seconds
