unable to login LinuxMint 18.1 preempt-rt linuxcnc
- kor
20 Apr 2018 17:23 - 20 Apr 2018 17:35 #109353
by kor
unable to login LinuxMint 18.1 preempt-rt linuxcnc was created by kor
Since a couple minutes I am unable to log in to my linuxcnc computer. once it boots up I get an error message your session took less than 10 seconds...
initclt: connection to upstrt not possible. failed to connect syndemon: no process found
/etc/mdm/Xsession:Beginning session setup...
localuser:kor beeing added to access control list
I got no idea what I have to do or can do. I would really prefer not to reinstall everything.
yesterday i did am update everything except the linux system.
Last edit: 20 Apr 2018 17:35 by kor.
- ozzyrob
- Visitor
21 Apr 2018 00:45 #109364
by ozzyrob
Replied by ozzyrob on topic unable to login LinuxMint 18.1 preempt-rt linuxcnc
If you go into grub advanced options you should have
1. A non upstart option
2. An upstart option
3. A recovery option
Try the non upstart option
- kor
21 Apr 2018 07:39 #109372
by kor
Replied by kor on topic unable to login LinuxMint 18.1 preempt-rt linuxcnc
This brings the same result.
even the generic kernel which is a different linux version gives that error.
I really need some help. at least I want to save my linuxcnc configs.
- Clive S
- Thank you received: 486
21 Apr 2018 08:44 #109373
by Clive S
Replied by Clive S on topic unable to login LinuxMint 18.1 preempt-rt linuxcnc
You might be able to stick the drive in another PC as a second drive and get the config folder from it.
- ozzyrob
- Visitor
21 Apr 2018 08:45 - 21 Apr 2018 08:55 #109374
by ozzyrob
Your best bet would be trying either ubuntu or mint forums. It would appear the issue is to do with the update, not so much a linuxcnc issue.
Have you tried the recovery option ?
Even if you have to reinstall you can boot the live version of Mint and copy everything to a usb stick, then do a reinstall
Before you chose an option press TAB and see if there is init=/sbin/upstart part to the "linux" line
Last edit: 21 Apr 2018 08:55 by ozzyrob.
Time to create page: 0.095 seconds
