Trouble finding files referenced in vismach tutorial
- Wireline
- Thank you received: 9
21 Apr 2018 20:35 - 21 Apr 2018 20:36 #109405
by Wireline
Trouble finding files referenced in vismach tutorial was created by Wireline
Hi
I am new to LinuxCNC and following the vismach tutorial here wiki.linuxcnc.org/cgi-bin/wiki.pl?Vismach
I have reached the section under "get familiar with HAL", just after using halrun and bringing up the 5axisgui vismach 3d representation. I am running a build in place installation.
I am unable to find the file it references in this line:
Under the linuxcnc directory there is no folder called 'config', and the folder called 'configs' does not contain any hal file with reference to 5axisgui. Is the tutorial out of date? If so how do I find the file? The previous section works ok with running 5axisgui in halrun, so I am assuming it must be somewhere.
Cheers
Now go to your /home/usr/linuxcnc/config/your_machine folder and edit the .hal file. Add at the bottom the line:
loadusr -W 5axisgui
Cheers
Last edit: 21 Apr 2018 20:36 by Wireline.
- Thank you received: 4648
01 May 2018 21:24 #109946
Replied by andypugh on topic Trouble finding files referenced in vismach tutorial
I haven't seen that tutorial before.
Is this one any more help?
linuxcnc.org/docs/2.7/html/gui/vismach.html
Do you get this dialog box asking if you want to make an editable copy?
Time to create page: 0.369 seconds
