I/O does not exist ERROR message Debug file
- sharp_reaper
- Thank you received: 7
23 Apr 2018 15:35 #109494
by sharp_reaper
I/O does not exist ERROR message Debug file was created by sharp_reaper
I was trying to add a handwheel in my work in progress and change the hal file to add the mpg and I can't do it, so I decide to do a restart . And I erase the code in the hal file that I just add for the handwheel. The error says that the output doesn't exist. I create another file using the pnfconf and says the same thing.
I've recently succeed moving a servo and now that happened.
Thanks,
Thanks,
- Thank you received: 5321
23 Apr 2018 16:01 #109497
Replied by PCW on topic I/O does not exist ERROR message Debug file
The digital I/O section of the 7I76E was not found
Do you have field power (8V to 32V) on the 7I76E's digital I/O section? (TB1)
Is W8 in the left hand position?
- sharp_reaper
24 Apr 2018 07:29 #109530
by sharp_reaper
Replied by sharp_reaper on topic I/O does not exist ERROR message Debug file
Hello PCW,
Thank you for your reply.
I was trying to config digital input (axis selection and multiplier for mpg), then i got the error. My next step was to deleting code that could cause the error.
I end up to reflash the firmware,board, now it is ok.
Time to create page: 0.818 seconds
