Need help with 'Joint following error'
- stioc
24 Apr 2018 05:33 - 24 Apr 2018 05:36 #109529
by stioc
Need help with 'Joint following error' was created by stioc
So I've been running linuxcnc for a couple of months and so far things were going great until a couple of days ago when I ran an engraving gcode with lots of small movements. The code runs for a while and then I get the joint following errors. This is a stepper motor based system (in fact, I can run the gcode without even turning on the drivers and I still get the same errors, as expected). Looking at the wiki all it says is that I may have the ini file setup incorrectly but I have no idea what I'm looking for. Any help would be much appreciated.
Edit: Nema 23 Stepper Motors 2.8A 269oz.in with a generic parallel port BoB and TB6600 based drivers.
Here's my ini file:
# Generated by stepconf 1.1 at Sun Mar 4 15:55:38 2018
# overwritten when you run stepconf again
[EMC]
MACHINE = RF30
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 0.10
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 0.25
INTRO_TIME = 5
PROGRAM_PREFIX = /root/linuxcnc/nc_files
INCREMENTS = 1in .5in .05in .01in .005in .001in
PYVCP = custompanel.xml
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = RF30.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
MAX_VELOCITY = 0.25
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
MAX_ACCELERATION = 1.0
STEPGEN_MAXACCEL = 1.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -15
MAX_LIMIT = 15.0
HOME_OFFSET = 0.0
BACKLASH = 0.009
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -1
MAX_LIMIT = 7
HOME_OFFSET = 0.0
BACKLASH = 0.019
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4
MAX_LIMIT = 1
HOME_OFFSET = 0.0
#BACKLASH = 0.023
Here's my ini file:
[EMC]
MACHINE = RF30
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALFILE = RF30.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
MAX_VELOCITY = 0.25
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -15
MAX_LIMIT = 15.0
HOME_OFFSET = 0.0
BACKLASH = 0.009
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -1
MAX_LIMIT = 7
HOME_OFFSET = 0.0
BACKLASH = 0.019
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 0.25
SCALE = 20000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4
MAX_LIMIT = 1
HOME_OFFSET = 0.0
#BACKLASH = 0.023
Last edit: 24 Apr 2018 05:36 by stioc.
- Thank you received: 5321
24 Apr 2018 13:20 #109542
Replied by PCW on topic Need help with 'Joint following error'
You might try doubling your "STEPGEN_MAXACCELs"
The stepgen must accelerate twice as fast as normal during
backlash compensation moves, so needs additional headroom.
The following user(s) said Thank You: stioc
- stioc
24 Apr 2018 16:01 #109553
by stioc
Replied by stioc on topic Need help with 'Joint following error'
Thanks PCW! I'll try that tonight. I see that's also suggested in the INI config man page. Can I ask what the "stepgen" is exactly? At first I figured it was a piece of software code that generated steps but that might not be correct since you said it must accelerate twice as fast so it's something physical? Sorry if that sounds as dumb as it feels to ask lol
24 Apr 2018 16:38 #109556
Yes, in this case, the stepgen is a software component that generates the step pulses
(and handles direction and direction timing)
The stepgen component has settable limits on velocity and acceleration, The acceleration limit needs
to be set a bit higher than the stepgen will ever be commanded to accelerate
(and during backlash compensation the commanded acceleration can be double the axis acceleration limit)
- stioc
25 Apr 2018 04:45 #109572
by stioc
Just ran the gcode after changing the stepgen_max to 2 and it worked! Thanks so much!
Time to create page: 0.293 seconds
